Re: Re: Magneto switch to Distributor on a Farmall Super C ?
Posted by peter on March 11, 2002 at 19:30:47 from (161.184.182.140):
In Reply to: Re: Magneto switch to Distributor on a Farmall Super C ? posted by Haas on March 11, 2002 at 06:10:15:
Standard equip. was batt.ign. for super C ;mag was an option.late model A.s SuperA.s and some of the last few C,s[mine included] had batt.ign. so there are lots around.Simple change over two bolts and the ignition switch needs to be changed to a two pole-going from a mag grounding switch to be able to energising coil.
Post A Followup
: Re: Re: Re: Magneto switch to Distributor on a Farmall Super C ?
