Farmall Tractors Discussion Board |
Re: 300 Utility hydro-touch valve
Posted by Ray on August 02, 1999 at 17:42:32 from (216.46.132.205):
In Reply to: 300 Utility hydro-touch valve posted by Tom on August 02, 1999 at 14:09:38:
Do you have a check valve on the hitch? If you do and it still drifts down then the check valve is at falt. It could also be worn seals in the lift cylinder. Ray
Post a Followup
