Re: 1929 McCormick-Deering 10-20
Posted by Bob Kerr on March 12, 2002 at 06:07:08 from (205.188.193.23):
In Reply to: 1929 McCormick-Deering 10-20 posted by Randal Simmon on March 11, 2002 at 13:46:52:
Hi Randal and Will, I wish I had my 10-20 here so I could look at it! It is at the old farm 2 hours away right now. Randal, I would try to back off that rod some and see what happens. When I got my 10-20 going I didn't have to do anything to the governor, but it would stick at wide open throttle if I moved the lever up there and then moved it back to idle.It would also do it if I went up a hill and the gov openedthe throttle some, the speed wouldn't slow back down after getting back on level ground. It would idle back down if I bumped the carb and linkage some. What was causing that was the pot metal part sticking out of the side of the governor. There is an adjusting spring inside of that and it was gunked up some. After I got it cleaned out, I had to adjust it a little tighter to give just a little tension on it. It sounds if there may be too much tension on yours! If you replaced parts and then put the rods back on exactly like they were before the correct adjustment may be off. If you just put the rods back on then it will need adjusting.I don't think my overhaul manual said anything about gov adjusting, That may have been covered in an IH service book which I don't have one of those. I just sat down and played with it until it was working perfect. It was the first governor controlled engine I ever worked on in my life so it was a learning experience and some things seemed "backwards" to me. (like the throttle wide open when off and the lever at idle postition)Let me know what you find.
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
