Farmall Tractors Discussion Board
Re: Follow-up to Overhaul Break-in Procedure on H
Posted by Phil Auten on August 02, 1999 at 19:41:11 from (206.175.72.226):
In Reply to: Follow-up to Overhaul Break-in Procedure on H posted by Bill(Tx) on August 02, 1999 at 15:57:49:
Bill,
Whew! I'll bet that you would've made the doctor blanch if he'd had you hooked up to an EKG when that squeal started! Hope the fix is as easy as it sounds.
Phil
Post a Followup
: Re: Re: Follow-up to Overhaul Break-in Procedure on H
