Farmall Tractors Discussion Board
Re: wiring problem
Posted by ltf in nc on August 02, 1999 at 19:46:14 from (206.228.213.161):
In Reply to: wiring problem posted by TOM R on August 02, 1999 at 19:25:20:
I do not have a manual but I think I can get you started with this repair. The hot wire from the battery goes to the BAT terminal. This wire is probably being fed from the battery cable connection at the stater solenoid. The IGN connection goes to the primary wire on the coil. Just go to the coil and follow it back to the switch area. The ST terminal goes to the coil of the starter solenoid. One of the farmall guys will have to tell you about the fuse.
Post a Followup
: Re: Re: wiring problem
