Re: Bob M, other electrical guys...
Posted by Bob M on March 16, 2002 at 07:14:41 from (66.66.72.246):
In Reply to: Bob M, other electrical guys... posted by Steven@nd on March 15, 2002 at 18:27:13:
Steven - All of the ideas below will work, though with a couple of clarifications:
1 - Wire the Hobbs meter "-" terminal to the regulator GEN terminal. (Assumes you have a positive ground system - if your tractor is negative ground connect the Hobbs "+" terminal to the GEN terminal) The meter should run whenever the motor is running, even when the generator is not charging (3 or 4 volts appears at the GEN terminal even at low idle...)
2 - The pressure switch idea will work - though you gotta use a NORMALLY OPEN pressure switch (one that closes it's switch contacts when it senses pressure) for this to work. Note: Nearly all vehicle oil pressure switches are NORMALLY CLOSED - contacts close on loss of oil pressure. So you can't simply grab any old oil pressure switch and have this one work.
3 - Replace the stock magneto kill switch with a DPDT toggle switch. If you wire it correctly, no relay is required.
I personally prefer #3...
Post A Followup
: Re: Re: Bob M, other electrical guys...
