Champion plugs?
Posted by Trusty on March 18, 2002 at 18:38:17 from (64.12.107.178):
I have a '39 M. I replaced the plugs in mid-September. Using the Champion D18Y gapped to .030-.035. Have two that have gone bad. New distributor cap, rotor button, condenser, coil and plug wires were put on at the same time. I use the tractor every day for around 45 minutes feeding hay. It does not use oil. Has run good until today. Is there a better brand or is this just something that happens sometimes? Also is there a remedy for moisture inside the distributor cap? Thanks for your help.
Post A Followup
: Re: Champion plugs?
