Re: Re: Re: How to use TA?
Posted by kev@ia on March 18, 2002 at 20:59:16 from (206.72.15.144):
In Reply to: Re: Re: How to use TA? posted by RAW in IA on March 18, 2002 at 11:39:05:
Shift her fast, like 1 or 2 seconds, if it jerks try throtteling back a little as you make the up shift. If your not towing anything get into 5th direct drive then open the throttle all the way, ta shifts at lower engine speeds wear the ta very little.
When slowing leave it foreward and throttle back, think ahead as a heavy load can push you where you do NOT want to go.
While some guys final wish is to die on their tractor, please don't let it be because of an accident.
kev
Post A Followup
: Re: Re: Re: Re: How to use TA?
