Farmall Tractors Discussion Board
Re: WILL THE M RUN?
Posted by Bob M on August 03, 1999 at 11:33:40 from (192.232.120.194):
In Reply to: WILL THE M RUN? posted by RANDY on August 03, 1999 at 10:11:02:
I acquired an M under similar circumstances. Had good luck doing the following:
1 -Drain the oil and refill with fresh. Put in a new filter too.
2 - Remove the spark plugs and shoot a couple ounces of motor oil or WD-40 into each jug.
3 - Now see if you can turn the motor. If you can, give it several revolutions, then....
4 - Install new spark plugs.
5 - Pop the distributor cap and wipe it dry inside. Clean and regap the points, or install a new set.
6 - Dump the gas tank, clean the sediment bowl and drain the carb (plug on the bottom of the carb bowl). Put in a couple gallons of fresh gas.
7 - Stick in a fresh battery, cross your fingers for luck and crank 'er up.
Good luck!
PS - Good idea to check for wasp nests around the fan, in the battery box, etc. before doing the above - I did not and wished later I had...
Post a Followup
: Re: Re: WILL THE M RUN?
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
