Farmall Tractors Discussion Board
Re: Grandpa's old F-20 (?)
Posted by TMAC on August 03, 1999 at 17:49:43 from (207.144.168.254):
In Reply to: Grandpa's old F-20 (?) posted by Ronny Bailey on August 02, 1999 at 20:07:49:
Check one side of the clutch housing. If it has a one bolt mount, its a F20, if its two bolts, it is a F30.
Post a Followup
: Re: Re: Grandpa's old F-20 (?)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
