Farmall Tractors Discussion Board
Re: Grandpa's old F-20 (?)
Posted by Farmall Gray on August 03, 1999 at 19:32:11 from (205.188.193.156):
In Reply to: Grandpa's old F-20 (?) posted by Ronny Bailey on August 02, 1999 at 20:07:49:
The early F-20 and F-30s had an all cast iron steering wheel. It sounds like you might also have
the "duckbill" steering gear housing. That would make it an early tractor. Check the post below
about the clutch housing bolts. Also while you are in that area, look on the top of the left frame rail. The serial # should be stamped there near the clutch housing.
Post a Followup
: Re: Re: Grandpa's old F-20 (?)
