Re: Re: 300 starts fast...
Posted by Dick Davis on March 24, 2002 at 06:34:50 from (64.12.102.23):
In Reply to: Re: 300 starts fast... posted by Bob M on March 23, 2002 at 05:53:28:
Thanks, your suggestions are the same I'm working on. New 12 v coil is on, changed points, plugs and condensor, making new ignition wires now, and took off carb last night to check for dirt and crud. Surely that will improve things. Appreciate your help and will advise. Dick
Post A Followup
: Re: Re: Re: 300 starts fast...
