Re: Cub 184 with a stuck clutch
Posted by chris on March 25, 2002 at 10:44:04 from (65.69.164.239):
In Reply to: Cub 184 with a stuck clutch posted by Bama Binder on March 25, 2002 at 08:53:47:
I usually prop the clutch pedal down and leave it for a couple days,and if you can see between the disk and pressure plate you can insert something like a puttyknife or similar,a few small nicks in the clutch disk wont hurt anything but try not to tear out any big chunks when prying on it.but keep the clutch pedal propped down during all the time your working on it
Post A Followup
: Re: Re: Cub 184 with a stuck clutch
