Re: Farmall A Steering Arm
Posted by Hilltopper on March 25, 2002 at 14:13:13 from (208.235.13.89):
In Reply to: Farmall A Steering Arm posted by Gary on March 25, 2002 at 12:43:24:
I had mine off last year with no problem, but when I tried again this winter I had to use heat to get it to come loose. Even though all the bearings were good on mine, I found wear in the sector key. I replaced it and it is a lot better. I would recommend you replace it while in there. IH can get the key. Hope this helps
Post A Followup
: Re: Re: Farmall A Steering Arm
