rebuilt Farmall A - sounds like a John Deere when throttling up
Posted by Loren on March 26, 2002 at 12:27:38 from (209.150.202.19):
I completely rebuilt a 1939 Farmall A two years ago. I put in a new block, valve job done, ground the crank, and put in 3 1/8" sleeves and pistons. The original motor was in pieces with a cracked block when I bought it. It has a Zenith carb. and no electric start. The motor seems to start good and idles nice, but when I advance the throttle or let the clutch out into gear it sounds like "put-put-put" as the motor builds up speed, then it sounds normal again after the speed has stabilized. I have a Farmall B and a C, and they both have a lot smoother throttle increase. I've swapped the Zenith carbs. between the tractors, and that doesn't make any difference. I've messed with adjusting the magneto timing, but that doesn't seem to make much difference either, especially since it starts good and doesn't kick back. I had put a new thrust bearing in the governor when I put it back together, but I don't know if the governor is causing the problem, or if it's something else. Any ideas?
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
