Re: Re: I am looking at buying a 856 Diesel, Can anyone tell me the Pro's and Con's of the 856
Posted by Honkey on March 27, 2002 at 10:27:28 from (64.68.163.45):
In Reply to: Re: I am looking at buying a 856 Diesel, Can anyone tell me the Pro's and Con's of the 856 posted by Steven@nd on March 27, 2002 at 10:13:39:
All I have to add is, if you are going to use in for loader work you will want to add a hydraulic assist on the clutch. They are kinda stiff without it.
Keep your pto linkage lubed and don't slam it down. If you do it will create a hydraulic lock. If it binds and you jump on it to shut it off, you will shear the small pin in the pto valve. Pretty common problem on them.
Good luck
Matthew in SD
Post A Followup
: Re: Re: Re: I am looking at buying a 856 Diesel, Can anyone tell me the Pro's and Con's of the 856
