Re: Stuck valves
Posted by steve c on March 29, 2002 at 04:37:25 from (152.163.213.58):
In Reply to: Stuck valves posted by Dave on March 29, 2002 at 01:14:41:
yes sir, The best is to let it soak and use tranny fluid too. I had a 37 with the same problem. I pulled the tractor around in gear to work up oil pressure in motor before I started it. this one is a hand start. I timed the magneto and it came to live. SteveC
Post A Followup
: Re: Re: Stuck valves
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
