Re: Stuck valves
Posted by Michael Soldan on March 29, 2002 at 04:45:51 from (216.46.130.25):
In Reply to: Stuck valves posted by Dave on March 29, 2002 at 01:14:41:
Dave, I would agree with what you are doing, ATF has been widely used for valve sticking. "RISOLONE" is a product I have used on a sticking valve but that was on a running engine...an oil additive that is to lube valves, even have put some oil in the gas (Sucking out of a gallon can) to give everything some lube. A rubber hammer might just jar them loose. Are the intakes moving OK? If you do have to pull the head it won't be that bad a job but you will have the expense of a gasket set. It is amazing what lubricants and penetrating oils can do..I hope it works out easiest for you and good luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: Stuck valves
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
