Re: Stuck valves
Posted by Larry W. on March 29, 2002 at 06:05:12 from (216.146.126.158):
In Reply to: Stuck valves posted by Dave on March 29, 2002 at 01:14:41:
Dave,
If you are lucky, and sounds like you are, the valves just got stuck when you turned the engine over by hand. If so, they should loosen up like the engine did. If however, they stopped using the tractor because the engine got hot, and the exhaust valves stuck, then you know the game. I agree, you are on the right track, and it may just be fine. These old engines can take a lot of abuse, and neglect, and keep on ticking. Good luck.
Post A Followup
: Re: Re: Stuck valves
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
