Re: Stuck valves
Posted by F-Dean on March 29, 2002 at 06:05:23 from (12.84.232.132):
In Reply to: Stuck valves posted by Dave on March 29, 2002 at 01:14:41:
Dave,
I would suggest removing the plugs and turn the engine with another tractor and a "Twisted Belt" while lubricating the exhaust valves. Tapping on the stuck valves should allow you to get them working.
I would also suggest taking the lids off the block handholes to verify that each splash trough is getting oil - you can burn out a rod if the distributer in the pan is clogged.
Post A Followup
: Re: Re: Stuck valves
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
