Re: Well rested A
Posted by Farmer Bob on March 29, 2002 at 22:34:03 from (66.152.73.37):
In Reply to: Well rested A posted by Brian, Toronto, On on March 29, 2002 at 22:09:18:
I'd recommend changing oil along with the filter and drain the gas tank and carb completely. Fresh gas, charged battery, new oil, and some luck are usually a good combination. If it's been sitting that long you may have some water in the tranny and the final drives. If the weather is below freezing (0 C)I wouldn't drive it until it warms up. Condensation will sink to the lowest point and freeze leaving the lube sitting on top. Gears can freeze into the water pretty solid. Good luck with it!//FB
Post A Followup
: Re: Re: Well rested A
