Re: H distrubutor drive may be broken
Posted by The Red on March 30, 2002 at 12:47:10 from (12.84.244.37):
In Reply to: H distrubutor drive may be broken posted by KURT on March 30, 2002 at 10:23:19:
Kurt look at that big ol gear on the base of the distributor assembly that goes into the engine. Remove the nut and nut lock. You will see an oblong hole which should hold a key. That key is probably stripped and the gear is freewheeling on the magneto/distributor drive shaft.
Post A Followup
: Re: Re: H distrubutor drive may be broken
