Re: Re: 300U Hyd. Screen Clean?
Posted by big fred - almost forgot on April 01, 2002 at 20:11:06 from (65.219.139.41):
In Reply to: Re: 300U Hyd. Screen Clean? posted by big fred on April 01, 2002 at 20:05:23:
You'll need to drain the reservoir before you take the cover off. The drain is on the left side below the forward attach bracket for the fast-hitch cylinder, or, if you have power steering, it's where the power steering return line hooks up.
Post A Followup
: Re: Re: Re: 300U Hyd. Screen Clean?
