Re: Re: Re: 300U Hyd. Screen Clean?
Posted by big fred - what was I thinking? on April 02, 2002 at 06:58:13 from (12.13.226.16):
In Reply to: Re: Re: 300U Hyd. Screen Clean? posted by big fred - almost forgot on April 01, 2002 at 20:11:06:
Of course you don't have to unbolt the valves from the reservoir, you can just unhook the hoses. I guess I was just seeing what I have to do, since I plan on some other work at the same time. You still need to unhook the manifold that goes to the pump, though.
Post A Followup
: Re: Re: Re: Re: 300U Hyd. Screen Clean?
