Re: 300U Hyd. Screen Clean?
Posted by LanceM on April 02, 2002 at 03:13:08 from (199.46.198.230):
In Reply to: 300U Hyd. Screen Clean? posted by Bob Kirk on April 01, 2002 at 18:30:31:
The screen is attached to the cover so be careful when you set it down. The cover is very heavy so have help or be ready for the weight. I used a hoist when putting it back on since there is no good way to get up close. My screen was so clogged that it had collapsed so be prepaired to buy a new one, they are available at the dealer.
Post A Followup
: Re: Re: 300U Hyd. Screen Clean?
