Re: Exhaust pipe for 1950 H
Posted by The Dukester on April 02, 2002 at 15:02:32 from (65.89.19.161):
In Reply to: Exhaust pipe for 1950 H posted by Grant on April 02, 2002 at 11:53:33:
Regular 2" black iron pipe will work for your. exhaust pipe, but it doesn't seem like a good idea to make it the full length(30 inches or so) straight pipe because if you hit something with it, it will probably break the thread boss right out of the manifold rather than the pipe at the threads--Murphy's law you know.
Post A Followup
: Re: Re: Exhaust pipe for 1950 H
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
