Farmall Tractors Discussion Board
Re: HELP RED 44 not acting right
Posted by mjdelaney on August 05, 1999 at 04:24:18 from (198.167.60.43):
In Reply to: HELP RED 44 not acting right posted by Corky on August 04, 1999 at 14:09:10:
I went through this this past summer as I needed more speed to run a baler. There are limits to what you can expect for extra rpm's; no doubt the Red's tips will help you out.
H works at 1815 @ high idle and will turn 540 rpm at about 1650 rpm. The governor is fairly easy to adjust if there is not too much wear. I found if I tried to adjust "outside" the normal levels, the linkages started to bind up. I don't think there is any point at all to go beyond the rpm's range than what the tractor was designed for ... for every day use. The other linkage to check is the block up over the valve cover. There is an adjustment here which gives the governor feed lever a little more movement.
Good Luck!
Post a Followup
: Re: Re: HELP RED 44 not acting right
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
