Re: Re: How do I get this thing to run??
Posted by Loren on April 03, 2002 at 08:53:31 from (206.102.31.252):
In Reply to: Re: How do I get this thing to run?? posted by Bama Binder on April 03, 2002 at 08:46:35:
Is there a single engagement for the dist. shaft? Can it be installed with #1 not pointing to #1, i.e. a gear on the dist. shaft that can be installed in any position? If so start by confirming #1 TDC position of the rotor first.
Post A Followup
: Re: Re: Re: How do I get this thing to run??
