Re: How do I get this thing to run??
Posted by Try this on April 03, 2002 at 09:49:09 from (152.163.201.206):
In Reply to: How do I get this thing to run?? posted by Don(PA) on April 02, 2002 at 19:01:22:
This is a rather crude check that has worked for me many times when I was not sure if plug wires were in proper place. Remove wire from coil to distribitor cap place one of the spark plugs wires into coil and crank. If everything but firing order is OK it will start up on one cylinder and you have found your problem.
Post A Followup
: Re: Re: How do I get this thing to run??
