Farmall Tractors Discussion Board
Re: Farmall A - no water pump????
Posted by Rick K on August 05, 1999 at 05:12:28 from (205.181.231.254):
In Reply to: Farmall A - no water pump???? posted by shoe on August 05, 1999 at 04:43:53:
Water circulates because warm water is lighter than cool water. The warm water goes up, the cool water goes down and around and around it goes. Super-A's and 100's have water pumps. I believe that you can add a Super-A water pump if you water level up above the top radiator hose inlet, want. Never did it myself, so don't know all the details like brackets and stuff. Someone else may know more about it. Just be sure to keep the as water flow will stop without a water pump if the water level drops below the upper radiator hose inlet.
Post a Followup
: Re: Re: Farmall A - no water pump????
