Farmall Tractors Discussion Board
Re: Farmall A - no water pump????
Posted by Ray Matchell on August 05, 1999 at 05:18:58 from (130.110.51.188):
In Reply to: Farmall A - no water pump???? posted by shoe on August 05, 1999 at 04:43:53:
According to the shop manual for the A, the cooling system is called thermo-syphon. As the water in the block heats up, it becomes less dense and the cooler, denser water in the radiator 'pushes' the hot water out of the block and into the radiator, circulating.
Post a Followup
: Re: Re: Farmall A - no water pump????
