Farmall Tractors Discussion Board
Re: Farmall A - no water pump????
Posted by big fred on August 05, 1999 at 07:23:18 from (12.13.226.12):
In Reply to: Farmall A - no water pump???? posted by shoe on August 05, 1999 at 04:43:53:
A thread on the JD board several months ago pointed out the necessity of mixing the anti-freeeze and water BEFORE adding to the system when there is no pump. Apparently the difference in density between water and anti-freeze inhibits the thermosiphon effect and can result in overheating. Pre-mix and everything works as it should.
Post a Followup
: Re: Re: Farmall A - no water pump????
