Re: Re: MTA Governor Problem?
Posted by Dave on April 04, 2002 at 12:01:20 from (205.188.199.154):
In Reply to: Re: MTA Governor Problem? posted by Bob M on April 04, 2002 at 06:36:00:
Bob,
I think you hit it with the fuel starvation solution. I pulled the plug at the bottom of the carb, and a steady stream of fuel came out for a few seconds, then trailed off until it started to dribble down the side of the carb. Put the plug back in for a few seconds, and did the same thing. That quick jerk on the throttle was not enough of a test, as the fuel line had time to fill back up again. Under load it demanded more fuel. I'll figure out where the obstruction is this weekend. Thanks for your help.
Post A Followup
: Re: Re: Re: MTA Governor Problem?
