Re: Calcium Chloride -- Do I need it in the tires?
Posted by Jonathan on April 06, 2002 at 20:02:45 from (209.91.2.248):
In Reply to: Calcium Chloride -- Do I need it in the tires? posted by Frank on April 06, 2002 at 18:24:38:
If you plan on using it to cut grass I definatly wouldn't load the tires because the tractor will cut in alot more especially when the ground is soft and make ruts. you really only need the tires loaded if you plan on running a loader or use it for tillage equipment.
Post A Followup
: Re: Re: Calcium Chloride -- Do I need it in the tires?
