Re: Calcium Chloride -- Do I need it in the tires?
Posted by Denny Frisk on April 07, 2002 at 06:07:35 from (216.165.146.102):
In Reply to: Calcium Chloride -- Do I need it in the tires? posted by Frank on April 06, 2002 at 18:24:38:
My Super H has Calcium Chloride solution in the rear tires.. But then it was used for mostly heavy drawbar loads when Dad farmed with it...and now it has a loader on it. Each rear tire has about 450-500# of solution in it, the same as 3 wheel weights. I also have a set of CI weights on it and would like to find another set cheap. It has the stock size 12.4 X 38 tires on it. I agree with the others that if You don't need the weight, DON'T use the calcium chloride....
Post A Followup
: Re: Re: Calcium Chloride -- Do I need it in the tires?
