Re: Farmall H Surges at first sign of load..How to smooth out
Posted by jal-SD on April 08, 2002 at 12:21:22 from (64.68.166.199):
In Reply to: Farmall H Surges at first sign of load..How to smooth out posted by Scott L. Swanson on April 08, 2002 at 10:06:25:
Sounds like the link from the gov to the carb is installed improperly into the carb. There is a connection there that must go into the proper slot on the back of the carb's butterfly. If you miss the slot, the carb will function, but will surge. I'd check this link first. Take the two screws out of the link connection @ carb & loosen @ governor. Slide the pipe covering the linkage toward the governor-sometimes you can see w/o taking the carb off. (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: Farmall H Surges at first sign of load..How to smooth out
