Ultra Hard Start on H
Posted by Brian on April 11, 2002 at 21:24:43 from (152.163.207.66):
I think I've done every thing short of pull
starting my 47 H that I could do by myself. I
manually timed the mag to #1 TDC and have verified
firing at the right time and seen spark thats
gapped right. New dry cell battery installed and
recharched after each afternoon's attempts.
Compression is 110 on three cylinders and 100 on
one and if I can get her going again I will adjust
the valves hot as specified in the manual. Fuel
tank has been boiled out and internaly sealed ,
carb has been bench tested at 5psi for half an
hour. I get stong suction when I put my hand on
the intake manifold with the carb off. Sprayed
some ether up the intake manifold and didn't get a
snort from the motor. Prior to this the
H was erratic in starting but it did start and run
fine. I hope to get her to fire on the first rev
but I've never come across something like this.
Any ideas as to where I might have gone wrong?
Thanks for your help. This web site sure is
Post A Followup
: Re: Ultra Hard Start on H
