Re: Ultra Hard Start on H
Posted by Try this! on April 12, 2002 at 16:47:02 from (66.191.112.67):
In Reply to: Ultra Hard Start on H posted by Brian on April 11, 2002 at 21:24:43:
Hey Brian this does work or at least on a batt setup. If you don't have it timed correctly this will show you. Take the coil wire and stick it in one of the spark plug openings in the cap, which one doesn't matter, preferably one with higher compression. Give it a try. It will run on one cylinder. Then you can go from their. Good luck.
Post A Followup
: Re: Re: Ultra Hard Start on H
