Re: Re: C200 Engine....how do you check the crank bearings
Posted by Don on April 12, 2002 at 05:20:20 from (64.105.216.218):
In Reply to: Re: C200 Engine....how do you check the crank bearings posted by Honkey on April 11, 2002 at 18:59:51:
If you take the bearing caps off, can you reistall them with the old bearing or do you have to replace with new? Also the cap bolts are a hex head, similar to head bolts that strech. Can you reuse these cap bolts or do you need to replace them if you take then out?
Post A Followup
: Re: Re: Re: C200 Engine....how do you check the crank bearings
