Re: C200 Engine....how do you check the crank bearings
Posted by Honkey on April 11, 2002 at 18:59:51 from (64.68.163.36):
In Reply to: C200 Engine....how do you check the crank bearings posted by Don on April 11, 2002 at 14:12:44:
Take the caps off. If you spun a bearing you would see alot of shavings in the pan.
Matthew in SD
Post A Followup
: Re: Re: C200 Engine....how do you check the crank bearings
