Re: Re: Help Bob M. rewired 130 today
Posted by Hugh MacKay on April 15, 2002 at 05:52:30 from (209.226.106.99):
In Reply to: Re: Help Bob M. rewired 130 today posted by Bob M on April 14, 2002 at 19:28:32:
Bob: As you may or may not recall with the number of questions you recieve. My tractor is the one that trucking company left switch on during moving. Tractor arrived with cooked battery, original wireing harness melted. I had installed a new battery just before move so they wouldn't have trouble starting. Yesterday I installed a new Battery, 520 cranking amps, showing 12.5 volts at installation. I put all new wires on tractor as per your diagram two wire with alternator H & M. My tractor is a 130 so assume only difference is solinoid versus start lever on 130. I did not check out ampmeter or alternator as I have to drive some distance to do that. After starting tractor, I checked at several points with voltmeter and was getting 12-12.5 volt reading. After I shutt tractor off I put volt meter on at alternator, with tractor not running and ign. switch off I got 1-2 volt reading. Thinking that shouldn't be I removed ground from battery came to house, posted for your help. Upon reading your responce this am I went to shop connected battery, started tractor, after a bit of warm up I removed battery ground, tractor stoped immediately. I repeated and same thing. Ampmeter guage also does not go to neutral as it used to when tractor is shutt off. The ampmeter hand does move several points + when tractor is started and goes to + 5 when tractor is off. Two questions, 1. Should I have gotten that 1-2 volt reading at alternator with tractor off. 2. Tractor stoping when I removed battery ground leads me to believe alternator is not working. Is this alternator or just internal regulator. Also the fact that I did not get the 13-14 volt reading you speak of with tractor running, reinforces the thought that alternator is not working. I hope this gives you more to work with. As always thankyou very much for your responce. Hugh
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
