Re: Re: Re: Help Bob M. rewired 130 today
Posted by Bob M on April 15, 2002 at 09:01:56 from (165.170.128.66):
In Reply to: Re: Re: Help Bob M. rewired 130 today posted by Hugh MacKay on April 15, 2002 at 05:52:30:
Hugh - Now recall your "switch left on" incident - same thing's happened to me a couple times... Anyway here's a few thoughts/tips on your situation: 1 - The ammeter should read 0 with everything off, and -4 or -5 with the ign switch on and the engine stopped. If you are reading +5 with the switch on and motor stopped, the ammeter is wired for positive ground and is reading backward. Swap the wires to the two ammeter connections so it will read correctly. 2 - With the motor stopped, you should read battery voltage between the alternator BAT term and ground, also the alt #2 terminal and ground. The #1 terminal should read 0 with the ign switch off. #1 may show perhaps few tenths of a volt with the switch on. 3 - With the motor running and the alternator charging, you should again read battery voltage at BAT and #2. You should see a very low voltage (a couple volts max) at #1. 4 - Recall that upon startup the Delco alternator must be "spun up" to a speed higher than normal idle to turn on the regulator and start it charging. You can tell when this happens because the warning light will go out, the system voltage will jump to 14+ volts and the ammeter will deflect hard to the charge side. So after starting the motor, run it briefly up to full RPM before performing any tests! 5 - NEVER NEVER NEVER disconnect the battery cable on an alternator-equipped machine with the motor running! Alternators can self-destruct instantly under an an open circuit condition like this - maybe this happened to yours?? Hope this helps... Email me offline if you continue to have problems. ...Bob M
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
