Re: Re: Engine oil
Posted by Dave_Id on April 15, 2002 at 07:44:24 from (67.250.134.62):
In Reply to: Re: Engine oil posted by Jon with an M on April 15, 2002 at 06:43:37:
I agree with Jon. The oils made in the 1940's were far inferior to what can be purchased today. I use multi-grade also. I use #1 oil from Case/IH, I use the 15/40. I use multi-weight because it gets cold in the winter, and darm hot in the summer, but if you are in Texas of some place like that, go with straight 30w
Post A Followup
: Re: Re: Re: Engine oil
