Compression Ratio - CID PSI Compression
Posted by BIG JOHN on April 15, 2002 at 18:50:11 from (205.188.200.157):
I see it all the time where someone wants to know how much compression they should have in their various tractors. Most all of the manuals have the Compression Ratio (for an H - 5.9:1) and the Cubic Inch Displacement (again for an H - 152.1)but rarely is the Pounds per Square Inch given.
I see talk about a formula to figure the PSI using the Compression Ratio and the Cubic Inch Displacement.
Could someone please post this formula and give some examples.
THANKS FOR THE HELP
Post A Followup
: Re: Compression Ratio - CID PSI Compression
