Re: Compression Ratio - CID PSI Compression
Posted by Theman on April 16, 2002 at 05:55:00 from (12.19.86.5):
In Reply to: Compression Ratio - CID PSI Compression posted by BIG JOHN on April 15, 2002 at 18:50:11:
Below is a link to a page that actually does the calculations for you. Scroll down to the engine calculation section and pick 'compression ratio'. Granted, it has it's basis in drag racing but if you really want to run good numbers on your engine, this is a good place to go. I used them when blueprinting the engine on my H.
Post A Followup
: Re: Re: Compression Ratio - CID PSI Compression
