Radiator drain valve blew out!
Posted by K.B. on April 16, 2002 at 16:51:45 from (209.163.14.180):
This afternoon I changed oil on the 966, checked everything over, and hooked up the disk. Made two rounds, and the temp. guage started comming up, still wasen't leaking. Let it cool down, started disking again, looked down and saw coolant running out of the radiator drain. I shut down fast, grabbed the vise-grip, took the side panel off and tried to tighten, but it was was tight. What caused the drain to blow out? Do you guys think I hurt the engine by shutting down a little hot?
Post A Followup
: Re: Radiator drain valve blew out!
