Re: Radiator drain valve blew out!
Posted by Will@ont.ca on April 16, 2002 at 23:46:11 from (216.58.67.124):
In Reply to: Radiator drain valve blew out! posted by K.B. on April 16, 2002 at 16:51:45:
K.B. was the coolant coming out the drain pipe or the overflow tube?When you shutt it down was it steaming and groaning and surgeing and making all kinds of bear like sounds!!,if it was just steaming a bit you most likly caught it in time.If the drain pipe is broke a the rad the a hacksaw blade and cut the threaded piece that is left in rad in a couple places then take screwdriver and bend pieces inward and pick them out with pliers[neednose].Hoping everything is OK.Will
Post A Followup
: Re: Re: Radiator drain valve blew out!
