Re: M Hydraulic Questions
Posted by Steven@nd on April 17, 2002 at 10:29:06 from (165.234.131.231):
In Reply to: M Hydraulic Questions posted by Kilian in SW WI on April 17, 2002 at 08:54:58:
As for the loader, yes there are loaders that come with their own hydralic reservoirs. As for putting on a distributor pump and running it from that - this would probably not be a good idea. First, you will either need to find an M&W pump or an IH live pump, timing cover, and timing gears from a Super M thru 450. Even with these changes, that pump was not designed to run a loader although people have done it. For loaders I will not use anything but a PTO driven pump.
Power steering I think was a factory option on the Super M thru 450. There was a Behlen unit and a Char-Lynn unit also. I belive both of these came with a pump that was mounted to the side off of the governor. These setups will fit right on an M. You will have to cut the steering shaft to put the torque motor on. One of them went under the hood and the other went in front of the steering pedestal above the fuel tank.
Hope this helps.
Steven
Post A Followup
: Re: Re: M Hydraulic Questions
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
