Re: Re: Re: Re: H brakes
Posted by jal-SD on April 18, 2002 at 06:33:29 from (64.68.166.199):
In Reply to: Re: Re: Re: H brakes posted by Wayne Swenson on April 17, 2002 at 19:39:43:
I'm w/Wayne---DON'T WELD. Somethings gotta be wrong! The pivot shaft may have broken the spot welds on the triangle shaped pin holders & slipped on the shaft. Look at the pin holders carefully & see ifna you can tell if they've moved. I've seen that happen. Put one side into a vice & pull on the center of the pivot shaft w/pipe wrench (use a big one-ya put lotsa leverage on that shaft w/foot) & see ifna ya can get it to move. Or, someone else put a LH adjuster on the RH side. (Another $0.02 worth. jal-SD)
Post A Followup
: Re: Re: Re: Re: Re: H brakes
