Starter problems
Posted by Dan on April 18, 2002 at 08:10:01 from (64.216.143.66):
My 1952 Farmall Super M has been converted to 12 volt and the original starter has been re-bilt by an automotive electrical company to be suited for 12 volt current. Because this is a "hobby tractor," I don't need to start it very often. However, even with marginal use, the brushes keep getting "burned-up"...and at the cost of $95 to rebuild the starter each time, this is getting expensive.
Question: does anyone know a source for 12 volt starters, either that replace the original...or are close enough? As I recall, some GM pickup starters in the 1960's might fit and work adequately. Hence, if anyone has information on this...I'd be grateful to know.
Thank you very much.
Post A Followup
: Re: Starter problems
